SVT Forums
T56 Trouble Shifting - Synchros?
Old Sep 16, 2008 | 09:31 PM
ACSViper's Avatar
ACSViper
i put it in 5th, as well as 6th, and stepped on it, both times the boost went to max, but rpms and speed barely moved. took time to get either of them up. so does that rule out the clutch? also, it does have a steeda clutch quadrant with the firewall adjuster
Old Sep 17, 2008 | 12:27 AM
P.S.I.cho's Avatar
P.S.I.cho
yes basically what your testing there is to see if the clutch is slipping, if you floor it and the rpms dont seem to jump up into rpm abnormally (aka clutch slipping) then the clutch is not your issue, if you already have the quadrant and adjustable cable you may just need a good adjustment
CS2007
Jun 25, 2019 09:45 PM
Thunderball
15
Nov 22, 2015 11:49 PM
chrisdbassplayer
Oct 13, 2015 06:53 PM
Explosive
Oct 2, 2015 07:45 AM
ChampInSD
Oct 2, 2015 04:55 AM
