Termi Timeslips, post em please.
To BlowSVT, did you get your suspension dialed in right? I'm not too sure if I like the way the stance of your car is. Doesn't look like you'll get adequate weight transfer to the rear... ?
I could be wrong though...
i am still working on it. i only mae it to the track once lat year because the damn cluches keep going out. in some of the shots some guys have it was almost pulling the front tires. it does have a forward lean though. the 12" springs in the front just might not be enough. they are adjusted to sit at the highest setting but even with BBK lowering springs in the rear the backend sits a little higher. Its a nice looking stance but might not be ideal for the strip. Also i was running a 28" tire in the rear and my skinnies are 25" so that even adds more to the lean which might hurt the transfer. I picked up a set of 26" drag tires to give that a shot as well. Hoping it will help with the gearing and help it leve a bit harder. I should find out even more though this year when i can finally leave with some real power. April is only a few months away now. Winter sucks for cars.
I guess when you hit it hard on the dyno you'll find out. the dyno is not too forgiving on the clutches since there is not alot of wheel spin normally.
yeah it does. but i don't dyno on a dyno jet. I do it on a dynodynamics where we load the car just like on the street. With the double rollers on each side of the tire it is hard to spin them on there. There is even some variation with the rollers of a dyno jet. Locally the one at Hitech motorsport uses 3000 lb drums while the one at APS autoworks uses 1800lb drums. I like the DD the best since it seems to most closely replicate the street.
