SVT Forums
Termi Timeslips, post em please.
Old Jan 27, 2009 | 09:53 PM
  #31
livefast1's Avatar
livefast1
viper spec? if so, if it wasn't do you think the 28" tires would have been alright?
Old Jan 28, 2009 | 09:53 AM
  #32
Blownsvt's Avatar
Blownsvt
no it is not the viper spec. i have the normal cobra ratios. It just seemed like there was not enough gear to get it out of the hole with the little bit of boost i could get on the 2 step. Even dropping it from 53-5400 it would bog down to the point of stalling beacuse there is no tire spin at all. if i would ride the clutch out of the whole to keep the rpms up then it would make passes like the one in the video. if i tried to run it hard it would bog out and the 60ft would be in the 2.6- 2.8 range. I think with the current 2 step and 3.73 gears it would have been much better on the 28's. We'll see if it gets better on the 26" i picked up when the track opens. i also plan on testing out one of the new 2 steps that is allowing alot more boost on leave. adding all the addiotional power to the launch might make the 28" perfect.
Old Jan 28, 2009 | 07:19 PM
  #33
livefast1's Avatar
livefast1
were you trying to launch on the sct 2 step? doesn't it take a long a$$ time to build even just a little bit of boost on that?
Old Jan 29, 2009 | 12:05 AM
  #34
Blownsvt's Avatar
Blownsvt
yep i was just on the sct 2 step. it takes a few seconds to get it going. most i have ever seen in 7.5 on it but it usually is around 5 or so. not enough.
baddog671
Jul 26, 2016 01:20 PM
1Bad71
Sep 30, 2015 07:37 PM
guitarman376
Sep 30, 2015 05:54 PM
CS2007
Florida Regional Chapter
Sep 29, 2015 12:06 PM
jc409
Convertible Tech
Sep 26, 2015 08:28 AM
