SVT Forums
hp/tq
Old Nov 19, 2009 | 04:13 PM
gadway41's Avatar
gadway41
Default hp/tq
Question? If I get my car dyno'ed with 17" wheels, then have the car dyno'ed with 18" wheels and the o.d. of the tire increases by a full 1", will the dyno Numbers increase or decrease going to a larger tire o.d. size?
Old Nov 19, 2009 | 09:36 PM
Blownsvt's Avatar
Blownsvt
it will decrease becuase of the larger rotating mass. assuming all other factors are equal between the 2 runs.
Old Nov 20, 2009 | 05:55 AM
gadway41's Avatar
gadway41
Let's say the mass is exactly the same, for debate purposes... More or less? With the larger wheel?
Old Nov 20, 2009 | 10:48 AM
jthorn9's Avatar
jthorn9
The Godfather
Will be the same, because the over all diameter of the wheel/tire itself doesn't change, cause 18" rims use thinner tires. But in reality, you'll loose power, that 1" more in the rim weighs more than you think.
Old Nov 20, 2009 | 11:18 AM
gadway41's Avatar
gadway41
The answer is, and this is base I my original question, The Horsepower will stay the same, but the torque will decrease.
Remember I said the tires Outside Diameter is larger for the 18" versus 17" and the mass is exactly the same.
Old Nov 20, 2009 | 12:10 PM
Fobra's Avatar
Fobra
Banned
http://www.audizine.com/forum/showthread.php?p=4416002
also read up on sprung vs. unsprung weight
Old Dec 16, 2009 | 02:10 PM
SpectorV's Avatar
SpectorV
18s vs 17s you have the same overall diameter (including tire) so the speedo wont be off. Every 1lb of extra rotating mass is about the same as 10lbs of dead weight.
Old Dec 16, 2009 | 04:30 PM
Xemeth's Avatar
Xemeth
Are you people illiterate? He said in the first post...
Therefore he means that if he dyno's with a 275/45/17, he's probably going to dyno with a 275/45/18 tire so the aspect ratio won't change and the overall diameter will increase by the 1".
Old Dec 16, 2009 | 05:05 PM
gadway41's Avatar
gadway41
Thankyou! Mr. Xemeth.
regards,
jEFF
millertime01
Oct 21, 2006 04:26 PM
chazrinehold
Sep 19, 2006 11:56 AM
bigmackloud
Jul 30, 2006 11:55 PM
dimebag
Jul 24, 2006 10:47 PM
hrd2bslw
Apr 10, 2006 11:17 PM
