SVT Forums
cobra problem
Old Jan 12, 2010 | 01:28 PM
shawnkaleb's Avatar
shawnkaleb
Default cobra problem
i have a 1996 cobra. i was needing some help getting my car back to normal, i just did the heater core and two days later it started to white smoke out of the exaust and the motor was really shakey. yes it did heat up but it did not over heat. both cylinder sides are full of water from raditor. i need some help knowing if i cracked block or head, need head gaskets or even freeze out plugs. the car woulnt start now. i put pressure into one of the cylinders and the air came out of the raditor cap. please give me information
Old Jan 12, 2010 | 01:48 PM
DarkDigital's Avatar
DarkDigital
You could do a comp test to see where it's coming from but your best bet is to pull the heads and look to see if you have a bad gasket.
I would try stop-leak first, worst case scenario you waste a few bucks and half an hour of your time.
Worst case scenario you cracked something in your block and water is seeping it.
Old Jan 12, 2010 | 02:07 PM
JC316's Avatar
JC316
Bad idea. It's like using a band aid to hold your guts in after a bear mauled you.
Pretty clear to me, you have massive amounts of water in the cylinders and air is blowing out the radiator cap, you probably cracked a head or had one major blow in the head gaskets.
Old Jan 13, 2010 | 06:36 PM
shawnkaleb's Avatar
shawnkaleb
well it is official i have a warped head and the other is cracked. i have a few questions, would the 2003 cobra heads fit onto my 96 block, and where is some decent prices at i have had trouble finding heads for it. would i be better off sticking to the 96 heads? thanks
Old Jan 14, 2010 | 01:26 AM
my94pony's Avatar
my94pony
yes the 03 heads will fit yours its called a c-head swap. use the search function is the best advice i can give u theres quite a few thing you would need for the swap
Old Jan 14, 2010 | 01:58 PM
JC316's Avatar
JC316
Probably not worth it to swap out TBH. You will need a new intake among other things. I would say find some Mark VIII heads, they can usually be had for around $100 each, put your cams in, and slap it all back together.
Old Jan 14, 2010 | 02:14 PM
my94pony's Avatar
my94pony
+1 and i believe our cams were better then the 03/04 too
Old Jan 14, 2010 | 02:19 PM
Mr99cobra's Avatar
Mr99cobra
I have mark VIII heads i need to get rid of in Missouri. Interested?
Nov 10, 2015 11:39 AM
TorinoCobra070
SVT Forums
Sep 18, 2015 10:34 AM
Scottyboy187
SVT Forums
Sep 13, 2015 10:23 PM
rdog69t
SVT Forums
Sep 13, 2015 06:16 PM
Sparks_88
Sep 8, 2015 01:06 PM
