Supercharger Choice?
Good argument. All valid points. All solved by running a dry shot. Solenoids can fail all day long and you'll never hurt the engine. Only wet or direct port kits with fuel solenoids run the risk of engine damage. Also, on the pro side of N20...solenoid failure rate is less than 5% per 100,000...and that's all dependent on usage as well.
(Colorful statistic taken from tech dept. of a reputable N20 manufacture.)
Nitrous and superchargers do exactly the same thing. Nitrous just does it chemically instead of mechanically. So with your logic, it's just as dangerous to run a supercharger. Ever heard of a bypass valve failure? Replacing a noid is much cheaper than replacing a head unit.
Everyone also says turbos are the way to go in this guys case...turbo's are the least forgiving. One slip of the boost controller, or "just one more pound of boost" moments, and that FAAARRRR more destructive than ANY 100 dry shot.
Of course a supercharger is not safe, neither is a turbo... but they are 1000x more reliable then nitrous. Any time you push the limits your risk damage... thats why its not worth it to do stupid things like "see how much you can get out of 93"..."how much power my stock rotating assembly will hold" ...for what purpose?
I also wonder how you think boost and nitrous not the same? They are both means to inject more air...or oxygen to be specific. I'm anxious to hear your explanation.
That's your opinion and you're welcome to it. I'm just trying to give the OP factual experience, and the best "bang for the buck" for his limited budget. For the 6-7 nitrous kits you can buy in lieu of one supercharger or turbo kit, it fits his budget better than anything else. And even in the worse case scenario of an engine failure, he still would have more $$$ to replace a motor than if he blew his budget on a $5K blower.
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
mungodrums
Suspension
Sep 24, 2015 10:12 PM
