MECHANICAL AFTERMARKET OIL PRESSURE GAUGE
If you're going to run the oil line inside the car, get a stainless steel line! ...My Auto Meter OP Gauge just took a dump (not common), so I replaced it with a volt meter....
You will need to find a place to tap into the oil ... the 03-04 Cobra's have a self tapped plug on the oil cooler...other then that, straight forward!
