SVT Forums
NEW: Idlers, Brackets and 4 Pulley Kits for the 03-04 Cobra
Old 06-06-2011, 09:23 PM
Boostaddict
Former Sponsor
Boostaddict's Avatar
Default NEW: Idlers, Brackets and 4 Pulley Kits for the 03-04 Cobra
IN STOCK WITH SAME DAY SHIPPING!!
4 Pulley Kits
http://www.lethalperformance.com/pul...-black-p-37177
http://www.lethalperformance.com/pul...-black-p-37176
New at Lethal Performance for the 2003 and 2004 Cobra is our own 4 piece idler kit which features our dual ball bearing billet idlers. The bracket and idlers are designed to put extra tension on the supercharger belt in order to help prevent belt slip and boost loss. In addition it removes any chances of the stock stamped steel idlers from exploding which we've seen happen many times. All of the brackets are cnc machined billet aluminum and hard coat anodized in black. It installs using stock mounting points and come with new high grade hardware. The idlers included in this kit are also cnc machined high grade billet aluminum which are hard anodized for a long lasting protective finish. Our idlers use not one but two heavy duty ball bearings which are meant to last long and stand up to the abuse that these idlers see from being spun at high rpms. Also included is a cnc machined dusct cover which helps provide extra support for the idler as well as protecting it from dust and dirt in the engine bay.
Kit Includes:
(1) CNC Machined Billet Idler Bracket
(3) Billet Aluminum 100mm Dual Ball Bearing Idler
(1) Billet Aluminum 90mm Dual Ball Bearing Idler
(1) Hardware Pack
Bracket w/100mm Idler
http://www.lethalperformance.com/pul...-black-p-37172
http://www.lethalperformance.com/pul...-clear-p-37173
Kit Includes:
(1) Billet Aluminum 100mm Dual Ball Bearing Idler
(1) Hardware Pack
Individual Idlers
http://www.lethalperformance.com/pul...49_10850_11315
The new idlers we offer are not only the best looking idler to hit the market place but were also designed to be the best performing idlers as well. The design was inspired from our 2010 GT500 as the wheels on that car look amazing. Our idlers are cnc machined out of high grade billet aluminum which ends up getting hard anodized for a long lasting protective finish. It uses not one but two heavy duty ball bearings which are meant to outlast the single bearing design as well as stand up to the abuse that these idlers see from being spun at such high rpms. All of the idlers also come with a cnc machined dust cover which helps provide support for the idler and keep dust and debris out of the bearings.
These idlers not only work with our idler bracket but also can be used as a heavy-duty replacement for the two idler pulleys on the factory crossover bracket, and as a heavy-duty replacement for the factory crank idler on the 2003-2004 Mustang Cobra.
Features:
CNC Machined High Grade Billet Aluminum
Hard Anodized for a long lasting protective finish
Heavy Duty Dual Ball Bearing Design
Billet Dust Cover provides extra support and keeps dust and debris out of the bearings
Boostaddict is offline
jwog666
12-27-2021 08:09 PM
Dathan
10-05-2015 05:52 AM
mikesr4565
Suspension
09-21-2015 10:26 AM
09-16-2015 07:53 PM
Quick Reply: NEW: Idlers, Brackets and 4 Pulley Kits for the 03-04 Cobra
