SVT Forums
Changing coolant in a 04 cobra
Old Oct 3, 2011 | 07:37 PM
cobra21987's Avatar
cobra21987
Default Changing coolant in a 04 cobra
Hey guys i wanna change the coolant in my cobra and want to know what everybody puts in theres and is there anything i got to watch out for thanks
Old Oct 3, 2011 | 07:58 PM
Timspony's Avatar
Timspony
SVT Section Moderator
....I just put a 50/50 mix of Prestone (All Makes), some use Motorcraft...Fill through the cross over tube-the high point!!! ...If you fill through the radiator overflow tank, you will have a air pocket and overheat!
Old Oct 3, 2011 | 10:21 PM
757Mustang's Avatar
757Mustang
I just did that about a month ago and i hated it because i completely flushed it. I emptied is out of the system and and block. Just look up stepes from the sites. It helped me out alot.
Old Oct 4, 2011 | 05:15 AM
Blackvenom01's Avatar
Blackvenom01
from experience dont flush it...i have seen many times after a flush it moves around alot of junk in your radiotor and ends up clogging it or your thermostat...so i would just drain and refill
Old Oct 5, 2011 | 10:52 AM
Cobra Kai Dojo's Avatar
Cobra Kai Dojo
isn't it relatively easy to bleed out the air from the system? haven't done the coolant drain/fill yet on mine but can't you park at an incline with the cap open and let it warm up?
Old Oct 5, 2011 | 03:32 PM
Timspony's Avatar
Timspony
Go for it! ....But trust me, much simpler to re-fill through the cross-over tube! ..Then you won't have any worries!
Granatelli Sales
Jan 20, 2020 12:34 AM
Nick Oliver
Oct 17, 2018 04:22 AM
Nov 10, 2015 11:39 AM
MusicCity615
Sep 12, 2015 07:05 AM
Sparks_88
Sep 8, 2015 01:06 PM
