SVT Forums
Small Projects
Old Oct 15, 2011 | 12:06 PM
Rokgtar's Avatar
Rokgtar
Default Small Projects
The odometer on my 97 Cobra stopped working a week or so ago right at 145987... the fix was a new set of odometer gears... Them little buggers are expensive for all they are - $34.99! Got them from Late Model restoration. Ground shipping was about 10 bucks so I figured I'd make it worth my while and order a new TPS as well ($29.99).
Installed them both this morning - both installs went smoothly. As soon as I fired it up, it ran very rough but once the car "learned" that there was a new TPS, it smoothed right out. My idle is much smoother, and now the odometer works too (not sure if that is a good thing or not :-) ). The old gear was intact but had turned soft and brittle.
Sometimes its the little things...
Old Nov 7, 2011 | 06:19 PM
02GTman's Avatar
02GTman
Yeah, it feels good when ever you can take care of a problem yourself, big or small. :-)
Old Nov 12, 2011 | 08:10 AM
Rokgtar's Avatar
Rokgtar
Speedometer is still working great, but unfortunately the rough idle issue is back - it still has a miss in it. Could a diagnostic machine tell me where the miss is and why it is happening?
Old Nov 13, 2011 | 02:06 AM
02GTman's Avatar
02GTman
Have you tried cleaning the IAC? I'm pretty sure one of those diagnostic machine could tell you exactly where your problem is.
Old Nov 13, 2011 | 05:56 PM
Rokgtar's Avatar
Rokgtar
I replaced the IAC about a month ago... I think I will have a diag test done, to help me down the path a bit quicker...
4cylinderplus2
Oct 9, 2020 07:45 PM
daltron
Apr 28, 2016 08:10 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
UrS4
Sep 30, 2015 10:13 AM
ThatJuanStang
Sep 25, 2015 08:01 AM
