SVT Forums
Speedometer reading incorrectly
Old Oct 25, 2018 | 02:18 PM
Stimp's Avatar
Stimp
Default Speedometer reading incorrectly
I have a 97 svt cobra and just put a 98 motor 4.6 in it does anyone have a diagram for vacuum lines on top of motor? Also my speedometer is reading way fast I have a 19 tooth gear on side of trans would a 17 tooth gear correct this?
Old Oct 25, 2018 | 04:46 PM
imp's Avatar
imp
Works the other way around. A 17 tooth will read even faster. How much too fast is it reading? Take a reading by milepost to milepost holding speed constant, try 60 mph indicated on the speedometer. Should take 60 seconds per mile. If it took 55 seconds for example, you're off 5/60 or 1/12, or 8.3%.
Going to a 20 tooth gear will slow down the indication by 1/19, or 5.3% not enough. There used to be 21 tooth gears available, a 21 would slow it by 2/19, or 10.5%. That would get it pretty close. Any better would require changing the gear on the tailshaft, which may not be possible. A 2% error would mean when your speedo shows 100, you're actually doing only 96. imp
Old Oct 25, 2018 | 04:56 PM
Stimp's Avatar
Stimp
I appreciate the answer I will try to check next time I am out but I am going to say I am about 15 to 20 mph to fast. I think I am doing 55, 60 and speed says 80 but I will try to get an exact number
jimmys96stang
Jun 1, 2010 07:13 PM
mongolchuck
Feb 24, 2008 11:05 AM
lilrobo
Jan 4, 2008 10:07 PM
muggsy
Aug 13, 2007 10:12 PM
Mustangood
Mar 7, 2005 02:26 PM
