how much will zex kit drop my 1/4?
Previous best was low low 11's @~124 mph with 528 Whp. Was running out of fuel. Got the fuel problem fixed and 175 shot is getting installed soon.
More is getting done to the car besides the zex kit but let's just say I stay at 528 Whp then spray the 175 shot? ~ how much would come off the 1/4 time?
Not very familiar with nitrous. Car has full tubular suspension , coilovers and will now be using slicks. The m/ t drag radials worked fine before but trying out slicks this time.
with your slicks, if you run skinnies and can cut sub 1.7 60ft's and leave the line on your window switch spraying probably more than a second... spraying on the line with a platform that can handle the punishment and can actually put down the power is a beautiful thing
also, keep in mind you are from florida... that nitrous is going to cut through your humidity/heat problem like a hot knife through butter... not only will you be making better numbers but your car will run better in your given weather and D/A
^^ oh yea i forgot about the weather. But its just crazy hearing "yea im spraying a 175 shot on top of my KB 2.6" haha. Its gonna be retarded no matter what it runs.
PLUS slicks...you will have a handfull.
I have been looking into the killer chiller for the summer.
My goal is to run a 10 second pass on blower and a 9 second pass on nitrous. In my dd. My car drives lke stock at this power level. Until I go wot. Everyone onlinevsaid its crazy to have a kb car as a dd. Its possible to stay out of boost the whole way to work... doesn't happen ever... boost feels too good!
Thnk for the replys.
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
zanemoseley
09-06-2015 12:58 PM
