4.10's???
Old Feb 27, 2006 | 06:24 PM
MBish75's Avatar
MBish75
Default 4.10's???
What are 4.10's and how would they help my ride (04' V6 mustang)
Old Feb 27, 2006 | 06:29 PM
mustangman02232's Avatar
mustangman02232
Default RE: 4.10's???
its the axle ratio, stock is 3.27 and 4.10s will help your acceleration and cut your mpg by about 2 on the highway and might increase it around town if you can have a light foot, you will also need a t-lok or limited slip.
Old Feb 27, 2006 | 06:31 PM
03YellowPony's Avatar
03YellowPony
ORIGINAL: MBish75
4.10 is a gear ratio for the diferential. Stock, ours come with 3.27's. This is more of an "economy" gear ratio. By changing the gears to 4.10's, you are putting the power to the pavement MORE. For every one time the drive shaft turns, the wheels turn 3.27 times on a stock 99+ V6 stang. When you change the gears, for every one time the driveshaft turns, the wheels turn 4.10 times. Which means you can get up to speed faster.
Old Feb 27, 2006 | 06:36 PM
traveler's Avatar
traveler
I ♥ Acer
ORIGINAL: 03YellowPony
ORIGINAL: MBish75
And you don't need a t-lock or posi...it helps and would be wise but you don't need it.
Old Feb 27, 2006 | 06:39 PM
mustangman02232
ORIGINAL: traveler
ORIGINAL: MBish75
unless you want 1 wheel burnouts, you need a t-lok
Old Feb 27, 2006 | 06:42 PM
my04blaCk's Avatar
my04blaCk
I'm seriously thinking about 4.10's because i know a kid who might put them in for FREE or barely any cost. He's putting my lowering springs in for me at no cost. The 4.10's are only $150 on mustang tuning..how much RWHP do they usually add?
Old Feb 27, 2006 | 06:43 PM
traveler's Avatar
traveler
I ♥ Acer
A better idea...buy a 7.5 rearend...change out the gears when you can, keep driving then when you're ready take one out and put one in. A real posi would be much better than a t-lock...is there a 7.5 posi?
Old Feb 27, 2006 | 06:44 PM
traveler's Avatar
traveler
I ♥ Acer
it's not rwhp..it is rwtq
Old Feb 27, 2006 | 07:02 PM
NewMexMustang's Avatar
NewMexMustang
ORIGINAL: traveler
he already has a 7.5 rearend...there are t-locks and auborn possi's.
Old Feb 27, 2006 | 07:05 PM
traveler's Avatar
traveler
I ♥ Acer
where? I see 7.5 T-lock but I don't see 7.5 Positrack or Lockers.
i don't think you're following what I said
