question about this hose
so i bought a 95 v6 mustang and there is this hose that is off and sucking air hard and i dont know where it plugs into.It feeds off the line that goes to the PCV valve and goes threw a sensor and drops down on the passenger side and goes down to behind the front passenger tire where its just hanging there not pluged in and i cant find where it plugs in at so today i pulled the sensor that is in the hose line and it comes up Code # P0443 which is Evaporative Emission Control System Purge Control Valve Circuit Malfunction so i wanna know if someone knows what this hose is or where it goes im getting desprate =^D
THANKs
THANKs
RE: question about this hose
The line you're talking about goes to your EVAP canister located behind the right front wheel, inside the wheel well. You need to remove the right front wheel well to gain access to the canister. Odds are it's broken due to a collision.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
treesloth
09-28-2015 07:03 AM
