aggresive cam
Old Apr 5, 2006 | 05:29 PM
MACHJUAN's Avatar
MACHJUAN
Default aggresive cam
i want to get a more aggresive cam, the stock one sucks and need more serious performance mods. What cam is the best and what else is needed? I heard rpm(not rpmoutlet) sells one for 180 and is good. What other ones are good and will this seriously kill my gas!
Old Apr 6, 2006 | 10:57 AM
jthorn9's Avatar
jthorn9
The Godfather
Default RE: aggresive cam
The one listed in my sig will be a decent one. Go to rpm-mustangs.com, they have a googleplex of cams availible.
Old Apr 6, 2006 | 12:05 PM
MACHJUAN's Avatar
MACHJUAN
will it sound mean at idle and which do you recommend for me? can you explain those numbers and i heard 15rwhp is normal on n/a cars!
Old Apr 6, 2006 | 01:08 PM
Drizzt6534's Avatar
Drizzt6534
You should also get 1.8 roller rockers, if you are going to be that far down in your motor you might as well change those out also
Old Apr 6, 2006 | 09:54 PM
NewMexMustang's Avatar
NewMexMustang
www.supersixmotorsports.com has cams
Old Apr 7, 2006 | 01:02 PM
jthorn9's Avatar
jthorn9
The Godfather
The first set of numbers 215/220 is the intake/exhaust lift, that's how high the cam lifts the valves up, the higher the lift the more air that is let into and then out of the engine, the second set of numbers .495/.491 is the duration of each. The longer the duration, the more air that can be let in and out.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
