converting a v6 to v8
Old Apr 11, 2006 | 04:24 PM
mustangman02232's Avatar
mustangman02232
Default RE: converting a v6 to v8
ORIGINAL: Derf00
ORIGINAL: jthorn9
Ok so now you just need a new ecu, GT springs, shocks, 8.8" rear end, a GT drivetrain (maybe), wiring harness, GT speedo, speedo realibration, make sure you don't trip your security switch then the damn thing may never work, a GT cooling fan, and lots of other small things.
No difference in the springs, Shocks yes, rear end Definitely yes, harness yes, the speedo will be calibrated off of the ECU so nothing needs to be done there, especially if he goes with a tuner. GT cooling fan? Should be the same.
motor mounts, cross member, do you have a stick or a auto right now? if you have a auto right now and want to convert to the T-45 then good luck you will need it
Old Apr 11, 2006 | 09:17 PM
britt21's Avatar
britt21
when i first got my sixer, i thought about doing that, until me and my dad looked into it..
go ahead if you wanna lose more money
Old Apr 11, 2006 | 09:30 PM
nanaki's Avatar
nanaki
Retired MF Moderator
why would someone actually upgrade to a cobra motor? just as time consuming as swapping from a v6 to a GT motor. probably more so.
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
lovesilver
Members Mustangs
May 9, 2019 09:18 PM
jerrytubes
Oct 23, 2015 12:11 PM
guitarman376
Sep 30, 2015 05:54 PM
