AC
Old Apr 22, 2006 | 01:11 AM
  #21
randy78045's Avatar
randy78045
Default RE: AC
100-110 degrees...
it all depends on what you want....
Old Apr 22, 2006 | 01:15 AM
  #22
03YellowPony's Avatar
03YellowPony
Default RE: AC
ORIGINAL: jthorn9
Hmm.......I'll remember to test that one out next time I'm on the dyno, ya know, just to see for myself.
Don't bother. I'm A/C certified, and no it doesn't. Unless you are low on refrigerant. Then cus the compressor is spinning faster, the sensors can measure a pressure drop and kick it off. Kinda like an A/C lag. If it senses a drop in pressure, it kicks off so you don't burn up the compressor.
Old Apr 22, 2006 | 01:16 AM
  #23
penceman's Avatar
penceman
Default RE: AC
ORIGINAL: randy78045
100-110 degrees...
At least you have tinted windows. Try living in South Florida at 95 degrees without tinted windows and your car being outside for 7 hours.
What part of FL are you from 98ponycar?
Old Apr 22, 2006 | 01:18 AM
  #24
03YellowPony
Default RE: AC
ORIGINAL: penceman
100-110 degrees...
At least you have tinted windows. Try living in South Florida at 95 degrees without tinted windows outside after your car has sat in the sun the entire day at school.
I was in Islamadora last June, and at 5:30 am, the humidity was AT LEAST 100%. I got wet walking from the hotel room to the beach. It was ok, but never again!!
Old Apr 22, 2006 | 01:39 AM
  #25
SPE926's Avatar
SPE926
Default RE: AC
while Florida might not get as hot as Texas the humidity will make it feel 10x worse you'll walk out side and just start sweating and it gets real sticky it sucks
Old Apr 22, 2006 | 01:42 AM
  #26
penceman's Avatar
penceman
Default RE: AC
ORIGINAL: SPE926
EXACTLY!
I hate that sticky feeling.
Old Apr 22, 2006 | 01:50 AM
  #27
03YellowPony
Default RE: AC
ORIGINAL: penceman
ORIGINAL: SPE926
EXACTLY!
YUP! But seeing the sun rise over the ocean for the first time in my life was worth it. Been there, done that, never again..
Old Apr 22, 2006 | 01:55 AM
  #28
SPE926's Avatar
SPE926
Default RE: AC
you only had to visit imagine living down here!! between the heat, humidity, and hurricanes i'm suprised that people still seem to move down here!!
Old Apr 22, 2006 | 01:57 AM
  #29
03YellowPony
Default RE: AC
ORIGINAL: SPE926
My aunt lives in Ft Pierce..it wasn't so bad there. But the Keys?? NO FREAKIN WAY!!
Old Apr 22, 2006 | 02:30 PM
  #30
mustangman02232's Avatar
mustangman02232
Default RE: AC
ORIGINAL: jthorn9
It can drain up to 20 hp from your rear wheels, and it also burns a little more gas when turned on.
less then 50, AC off windows down, more then 50 windows up AC on, thank you mythbusters
wut aboot a vert though[&:]
