Spark plugs
Old May 3, 2006 | 11:16 PM
ByPopularDemand's Avatar
ByPopularDemand
Default Spark plugs
Ok so mine need replacing. Two questions
Do I need new wires to go with the plugs
and what would I need to buy for better plugs
Old May 3, 2006 | 11:19 PM
Lancerzor's Avatar
Lancerzor
Default RE: Spark plugs
ORIGINAL: ByPopularDemand
You can just replace the spark plus if you want (i suggest Bosch platinum 4) and you dont have to replace anything else but if you have stock wires you might as well get something a little better but nothing is needed
Old May 3, 2006 | 11:21 PM
ByPopularDemand
Hmm that sounds like a plan
Old May 4, 2006 | 01:57 AM
Autobadges.com's Avatar
Autobadges.com
Banned
Getting new wires with the plugs can only HELP as the stock ones are ok but there are better ones out there with better spark.....
may I recommend our StangWires located at www.AutoBadges.com
Old May 4, 2006 | 02:10 AM
Lancerzor's Avatar
Lancerzor
are 9mm spark wires or 8mm spark wires better?
Old May 4, 2006 | 02:39 AM
Autobadges.com
Banned
both just as good...9mm maybe a bit bit more
Old May 4, 2006 | 02:46 AM
Galaxie's Avatar
Galaxie
I run NGK G Power Platinum...Every vehicle I have ever owned I have always used NGK product...not sure why...but I have never had a problem with them
Old May 4, 2006 | 09:49 AM
Lancerzor's Avatar
Lancerzor
I've always heard there is very little difference in aftermarket wires, like after you take off the stock most of the other wires will be the same with little to no difference in performance.
Is this true?
Old May 4, 2006 | 12:55 PM
Autobadges.com
Banned
Well its never something that you say OMG WOW to...bc its not that HUGE of a mod, but the better spark does cause for the engine to run smoother
BOB ROME
Jul 26, 2023 01:54 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
breaking
Oct 2, 2015 01:27 PM
lmurf60
Sep 24, 2015 10:07 PM
