free performance?
Old May 14, 2006 | 02:28 PM
  #21
Jugador's Avatar
Jugador
Default RE: free performance?
ORIGINAL: mustangman02232
autobadges.com/preformance
if you're gonna shamelessly post links in a thread called FREE PERFORMANCE, at least spell performance right.
Old May 14, 2006 | 04:24 PM
  #22
mustangman02232's Avatar
mustangman02232
ORIGINAL: Jugador
my bad long night[&o]
http://autobadges.com/performance/
Old May 14, 2006 | 04:28 PM
  #23
ByPopularDemand's Avatar
ByPopularDemand
It still doesnt look free
Old May 14, 2006 | 04:39 PM
  #24
mustangman02232
ORIGINAL: ByPopularDemand
thats casue the only thing free gets you is junk
Old May 14, 2006 | 05:22 PM
  #25
alexr's Avatar
alexr
ORIGINAL: Clif Brohn
ORIGINAL: cr720
ORIGINAL: Lancerzor
you can also open your hood and take off that heat thingy cause its basically pointless and thats like 2-3lbs and less weight means more HP
...what's this "heat thingy" you're referring to?
The engine
Old May 14, 2006 | 10:32 PM
  #26
04Mach1DD's Avatar
04Mach1DD
ok 1 cats, they dont add much hp if you take them out, but it helps. cut them off. 2 not my idea "change the thermostat to the lowest temp you can get. 160 degree if you can get it, if not then 185 might be the lowest for it. Right now it will have a 195 in it. It makes the computer think its cold so it richens the fuel/air mixture and gives hp.", 3 take out the air resticter in your intake. 4 there a a rubber peice that goes into your fenderwall from the air filter box, remove it. Theres some easy, free things. also next time you change your oil, use synthetic oils, it gave me 9 hp(but a v8), it should help u out, and be better for your engine. Get some fuel injector cleaner, especially with 90xxx miles on it, it will help. check if u need new plugs/wires thats helps alot if bad. then last maybe get your hands on some HIGH octane racing fuel to clean out your system. Hope that helps ya out.
P.S. get some CARB CLEANER, buildup can take away up to 15horses!!!
Old May 15, 2006 | 08:48 AM
  #27
mustangman02232
ive said this before and i will say it again, do NOT touch the silencer, over 130 mile trip i got about 15 mpg with out it, i get around 20 normally
Old May 15, 2006 | 10:57 AM
  #28
hookedonkronik's Avatar
hookedonkronik
thanks for the post about the silencer and not to do it because I was seriously considering it, but what about that rubber peice that guy was talking about going into the fenderwall?
Old May 15, 2006 | 01:58 PM
  #29
mustangman02232
ORIGINAL: hookedonkronik
its not hard to take out and put back in, as long as you dont cut it, try it for yourself, but over aboot 130 miles my milage went down a bit, and no it was not from leadititus
Old May 15, 2006 | 03:35 PM
  #30
04Mach1DD's Avatar
04Mach1DD
ok, so your saying that if i get a k&n on a stock car(wich gets more air flow) i will get worse gas milage???
