free performance?
Old May 15, 2006 | 06:20 PM
  #31
highskewlmustnglvr86's Avatar
Default RE: free performance?
thanks everyone......and about the thermostat....will one from a 88 mustang fit my 98.... o and by the way it only has 67k miles on it.... thnx
Old May 15, 2006 | 07:35 PM
  #32
amrcnidyot's Avatar
amrcnidyot
you dont want to get a thermostat that is too cold. i dont remember what the lowest you should go is but i know your engine is designed to run at certain temps so running it too cold could hurt it
Old May 15, 2006 | 07:55 PM
  #33
kcocgibkcusuoy's Avatar
kcocgibkcusuoy
No, what's he's saying is that you shouldn't take the air dam off. I put a high flow K&N on my v6 and noticed an increase in MPG (about 2-3 MPG better), and a little extra toe for the kicks. I am not sure about changing the thermostat either, especially if it's your daily driver.
As for the "heat thingy" ... Are you talking about the insulation on the hood?
Old May 15, 2006 | 10:39 PM
  #34
mustangman02232's Avatar
mustangman02232
ORIGINAL: 04Mach1DD
ok, so your saying that if i get a k&n on a stock car(wich gets more air flow) i will get worse gas milage???
i didnt believe it either, but i tested it twice and my numbers were right[&:]
Old May 15, 2006 | 11:45 PM
  #35
Rook6's Avatar
Rook6
ORIGINAL: mustangman02232
ORIGINAL: 04Mach1DD
Well doesn't the increase in airflow increase fuel flow?
Old May 16, 2006 | 09:01 AM
  #36
mustangman02232
ORIGINAL: Rook6
ORIGINAL: 04Mach1DD
couldnt tell you, possibly it was sucking warm air from the engine instead of cold air from the fender,
Old May 16, 2006 | 08:37 PM
  #37
well i have a 185 thermostat from a 88 and i was wondering if it should fit right? thnx
Old May 16, 2006 | 11:32 PM
  #38
04Mach1DD's Avatar
04Mach1DD
dont think so, but give it a try
Old May 18, 2006 | 12:40 PM
  #39
ikewineb's Avatar
ikewineb
I actually made a custom "cold air kit" for my car. It really might be closer to a ram air system. I have a total of $5.67 invested, plus the cost of the air filter. I installed a drop in K&N air filter. Next, I cut off about half of the snorkel (rubber piece that attaches to the air box and goes into the fender well). Then, I attached a dryer duct hose to the air snorkel and ran it down into the front of the bumper. I attached an air scoop off of an F-150 upside down there the fog light would be. Then I simply attached the dryer duct hose to the air scoop.
I've been running this set up with everything else stock for about 3 years now. I greatly improved my fuel economy. I haven't dynoed it or anything, but you can feel that the power band has moved up to a higher RPM. Low end power feels about the same, but you need to turn more RPM's on take off. It did improve the top end. You really feel the differency between second and third. One advantage, is that I can stay in gear longer. I can run 1st to about 35 mph and second to about 75 -80, depending on how hard you push it. I never hit 5th. At interstate speeds in 4th, I am barley taching 1,800 rpm.
There was also a post earlier about shimming the throtle cable on the 99-00 models. I haven't tried that yet, but I figure I will try it on both of my cars. I could see where that could make a difference. I notice there is a lot of slack on both of my cars.
I hope this helps.
Old Mar 6, 2007 | 03:33 AM
  #40
TruXter's Avatar
TruXter
ORIGINAL: ikewineb
I hope this helps.
Pics? .. please?
