Some basic questions...
Old Jun 9, 2006 | 08:31 PM
redass02gt's Avatar
redass02gt
EXTREME Moderation
Default RE: Some basic questions...
I think the same light that goes on when you lift up the parking brake also goes on when the abs is activated during a hard stop. the one with (P)(!) or something like that.
Old Jun 9, 2006 | 08:50 PM
NYstang's Avatar
NYstang
MF Staff Snitch
yup, theres ABS.....but i tested for trac-lok in my driveway, left marks on both sides...what gives?
Old Jun 9, 2006 | 08:56 PM
mustangman02232's Avatar
mustangman02232
ORIGINAL: redass02gt
mine never has, and i know mine has kicked in quite a bit since i drive in snow
maybe the previous owner put one on, or maybe it was a factory freak?
Old Jun 9, 2006 | 09:01 PM
redass02gt's Avatar
redass02gt
EXTREME Moderation
your doesn't have the light or it hasn't gone on during abs use?
I think it says in the owner's manual that the little light goes on when you are either short on fluid in the reserve, the parking brake is up, or if the abs is active, but I'm not 100% sure, I don't think I've used the brake hard enough to activate the abs more than once or twice.
nothing like a jackass in a benz coming up a hill trying to illegally pass someone on a two-lane road while you're going down the hill to test the abs... [:@]
Old Jun 9, 2006 | 09:02 PM
mustangman02232
hasnt come on when the ABS was active, and i could feel and hear it pumping the breaks so i know it works
Old Jun 9, 2006 | 09:41 PM
03YellowPony's Avatar
03YellowPony
ORIGINAL: NYstang
One more test. jack up both rear wheels. Spin one by hand. If the other goes the oposite way, it doesn't have a T-lok. If both wheels spin the same way, it does.
Old Jun 10, 2006 | 12:55 AM
flash20's Avatar
flash20
in my v6 2001 mustang when u turn off the traction it only burns out with 1 tires but when u turn it on it does it with 2
Old Jun 10, 2006 | 12:56 AM
03YellowPony
ORIGINAL: flash20
Open dif..not a T-Lok.
Old Jun 10, 2006 | 12:38 PM
mustangman02232
ORIGINAL: 03YellowPony
ORIGINAL: flash20
yup, it applies the breaks to the one side like it has traction so the other one starts to spin
Old Jun 10, 2006 | 12:49 PM
jthorn9's Avatar
jthorn9
The Godfather
[sm=happy046.gif][sm=happy046.gif][sm=happy046.gif][sm=happy046.gif][sm=happy046.gif] I finally caught Harv giving (bad advice) or at least slightly wrong advice. The MAF, is the mass air flow sensor, that's the little black box thing that sits on top of the mass air meter, which is located inside your stock air box, although on a cai, it becomes the link between the front and rear end of the pipe work. But a lot of websites and people get this screwed up in general, but the MAF, and MAM, are two different things but work together to do the same job. That little button you're talking about is traction controle, you still have an open differential, it basically just stops you from spinning out on wet roads. In general, mustang V6s don't come with ABS, they tend to use traditional disc brakes.
CHEAP MODS
1.) CAI (only adds like 3 rwhp, but is a decent start)
2.) Pulleys (releases around 5-8 rwhp, helps saves on gas, but still isn't going to be that noticible)
3.) True Flow Duel Exhaust (adds around 5 rwhp, and gives a way better sound than stock, read our sigs for some ideas first)
4.) Diablo or X Cal 2 Tuner (only adds around 5 rwhp on a stock engine, but can do wonders with auto trannys)
5.) Gears and a T-Lok (I say do this first, it's not really a cheap mod, but is about the only one you'll feel a noticible difference with)
6.) ^Those should be enough to keep you busy for a while.[8D]
