Some basic questions...
Old Jun 10, 2006 | 12:57 PM
  #21
flash20's Avatar
flash20
Default RE: Some basic questions...
why would the diablosport tuner work better with automatics?
Old Jun 10, 2006 | 01:06 PM
  #22
jthorn9's Avatar
jthorn9
The Godfather
They both do the same thing, but the diablo allows you to do a little more tinkering than the X Cal does. But it allows you to tighten shift firmness to make the car shift harder and firmer (kinda like a shifter kit does), remove rev limits to hit higher top speeds, reset the shift points to allow you to set your car where it needs to be set for optimal shift performance, etc.
Old Jun 10, 2006 | 01:07 PM
  #23
mustangman02232's Avatar
mustangman02232
ORIGINAL: flash20
you can adjust shift points, firmness, limiters etc, liek a shift kit
Old Jun 10, 2006 | 06:44 PM
  #24
bdeuce's Avatar
bdeuce
get a chip to plug into the cars comp. tehy add like 30 hp
Old Jun 10, 2006 | 06:56 PM
  #25
flash20's Avatar
flash20
what chip r u talking about?
Old Jun 10, 2006 | 07:07 PM
  #26
mustangman02232
no chip adds 30 hp, a tuner does the most and only adds like 8
and go with diablo
Old Jun 10, 2006 | 07:38 PM
  #27
hwy1strat's Avatar
hwy1strat
i don;t think they add 30 hp that's what some of them claim tough
Old Jun 10, 2006 | 07:53 PM
  #28
NYstang's Avatar
NYstang
MF Staff Snitch
it seems like they mostly make better shifting and remove limiters then making more hp. question about ud pulleys tho- do i need the whole set or would certain ones work almost as good?
Old Jun 10, 2006 | 07:54 PM
  #29
03YellowPony's Avatar
03YellowPony
ORIGINAL: NYstang
All you really need is the crank pulley and a belt. The others MAY get you an additional 1-2 HP MAX. But the billet w/p pulley just looks good.[8D]
Old Jun 10, 2006 | 07:59 PM
  #30
NYstang's Avatar
NYstang
MF Staff Snitch
ok...i just looked at a motoblue 42%reduction pulley on rpmoutlet.com . it says something about using a lower output ASP balancer kit. whats that mean?
