Engine problem
Old May 14, 2004 | 01:13 AM
98ponycar's Avatar
98ponycar
Default RE: Engine problem
Kenbossy, you're right. If it was a rod knock, when you ground out each cylinder, the knock should have stopped or drastically decreased. Does it do it only at idle, or when the engine is under a load? Does the knock sound like a double knock? If it's a double knock, and you ground out the cylinder, and it still persists, you're looking at a wrist pin problem. If it's not a double knock, and it still persists when you ground out each cylinder, then you may very well be looking at a main bearing knock. Main bearing knock can not be isolated to a particular cylinder. The sound can also vary in intensity and disappear at times depending in engine load. I agree with everyone else when I say that I would just have to hear it for myself. I hope I was of some help. Good luck
Old May 14, 2004 | 05:08 PM
96SilverLT1's Avatar
96SilverLT1
The spark plug wire trick works sometimes but not always. I have seen some 3.8's with bad rod bearings do this. I would also think a wrist pin could be the problem. are you sure that it;s internal? does it change with RPM? do yurself a favor and remove the belt and run the car to make sure that it;s not an acsesory doing it. you can also take a long peice of hose and use it as a stethiscope to help pinpoint the noise. Good luck
djbigskrilla
Sep 20, 2022 01:04 AM
ShaneB26154
35
Mar 4, 2021 04:05 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
HIS S-197
Aug 10, 2015 05:47 PM
Pain.
Aug 7, 2015 10:48 PM
