1995 possible electrical problem - speedometer and odometer problems
Old Jun 30, 2006 | 09:10 PM
Blues's Avatar
Blues
Default 1995 possible electrical problem - speedometer and odometer problems
I just bought a 1995 v6 Mustang and the speedometer and odometer occasionally doesn't work. I was advised, from someone who my friends trust, that there is no speedo cable so this must be an electrical problem. Does anyone have advise on where I can get some info on how to track this problem down?
Thanks!
Old Jul 2, 2006 | 12:27 AM
Black96's Avatar
Black96
Default RE: 1995 possible electrical problem - speedometer and odometer problems
pull the cluster out and check the wires and connectors on the back...but more likely it's a loose connection at the speed sensor on the tranny. i've seen more than a few cars with wires where the insulation just seemed to shrink back and the wire touch every so often. when they do, the speedo/odo quit. they are both run by the same signal. your cruise may also act funny if it's on when the problem happens.
articman
Jun 21, 2018 11:45 PM
TfcCDR
Sep 14, 2015 12:08 PM
MasterLanMan
Sep 13, 2015 08:21 PM
zanemoseley
Sep 6, 2015 12:58 PM
5.0 kevo
Sep 3, 2015 06:24 PM
