Throttle Problems
Old Jul 12, 2006 | 09:25 AM
Crsytal Ice's Avatar
Crsytal Ice
Default Throttle Problems
Since I have put mu CAI in, a MAC one, my throttle resoponse has actually dropped. What I mean is that if say I am at the lights and they turn green and I give it some gas, my car wll cough a little almost, hard to describe the sound it makes, then go. It is all coming from the throttle body. Has anyon else with a 95 SN95 had this problem after putting a CAI on or know what this problem is?
Thnaks.
Old Jul 12, 2006 | 10:57 AM
Jefferson's Avatar
Jefferson
Moderator
Default RE: Throttle Problems
I don't really know whats going on with it, but have you cleaned your TB with cleaner? It could just be real dirty. or you can also check that it is opening properly, take off the CAI and have someone push the pedal and watch to see if the TB is opening all the way.
Old Jul 12, 2006 | 01:00 PM
BeachStang04's Avatar
BeachStang04
Whens the last time you've cleaned your airfilter??? And where did you get your CAI, if you say ebay i have no sympathy [8D]
Old Jul 12, 2006 | 05:12 PM
jthorn9's Avatar
jthorn9
The Godfather
Ok take the cai back off, check your maf sensor and make sure a spek of dust or dirt didn't land on it, that's the little metal thing inside your mass air meter. After that, check the throttle body to see if it's properly working and check it for any debries blocking the tb. If that's good, you did remember to unistall the ait, or reinstall it into the new tb right? If you did that, then reinstall it, and make sure that ther are absolutly no leaks, and that the seals are tight.
TfcCDR
Sep 14, 2015 12:08 PM
Sep 8, 2015 11:50 AM
94stangnewbe
V6 General Discussion
Sep 7, 2015 07:39 PM
zanemoseley
Sep 6, 2015 12:58 PM
5.0 kevo
Sep 3, 2015 06:24 PM
