2000 Mustang won't start
Old Aug 23, 2006 | 05:45 PM
kennethross's Avatar
kennethross
Default 2000 Mustang won't start
I have a 2000 mustang 3.8L. A few weeks ago it was backed into in the parking lot. Since then I have been having troulbe getting started. It wouldn't crank over. If I got it to crank over, it would be in the morning or at night when it was cool outside. I tried resetting the fuel pump switch a couple days ago and this only made it worse. Now the gas is not getting to the car and not starting up at all. Anybody have any ideas about this???
Old Aug 23, 2006 | 06:34 PM
mustangman02232's Avatar
mustangman02232
Default RE: 2000 Mustang won't start
battery, starter?
Old Aug 23, 2006 | 06:40 PM
P Zero's Avatar
P Zero
Battery. Replace it. If the OE one is in there then its 6 years old. Batteries on average only last about 5 years max. Take your battery out of your car and take it to sears or where ever they can do a LOAD TEST. Its important that they load test it because, it simulates the same load thats put on it when youre trying to start the car. Most places will only put a voltmeter on it, and theyll sayits good, even when its not. Go to sears its the best place, not to mention the warranty on diehard batteries is one of the best out there.
-P.
Old Aug 23, 2006 | 06:42 PM
mustangman02232
ORIGINAL: P Zero
-P.
optima
Old Aug 23, 2006 | 06:53 PM
jthorn9's Avatar
jthorn9
The Godfather
Battery - Most likely the source of your problem, only thing is that it shoud recharge itself after it starts, but if it's Ford factory, then it's old and needs to be replaced.
Alternator - If it cranks, but strains to run, it could be that the alternator is having a problem and isn't supplying your engine with the necessary power.
Spark Plugs and Wires - If it's struggling to start and acts like it's carring a boulder when you drive it could be bad worn out plugs and or wires. Replace both as sometimes spark plug wires tend to get stuck to the plugs and will be damaged when taking them off.
Bad Sensor - If a sensor suddenly goes out, who knows what type of crazy things will happen.
My advice is to take it to a shop and let them run a diagnostic on the ecu and see what they come up with.
Old Aug 23, 2006 | 07:06 PM
P Zero's Avatar
P Zero
Yeah optima's are REALLY nice batteries, but not worth the extra cash IMO. Unless you have some sort of crazy video/audio system in your car.
-P.
Old Aug 23, 2006 | 07:37 PM
mustangman02232
ORIGINAL: P Zero
-P.
not even for that, they can be mounted anywehre in anypositon etc, and are spiral cell
mmbrown
Sep 8, 2015 01:29 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
01blackgtconv
Aug 14, 2015 04:50 PM
daytooday
Aug 11, 2015 09:22 AM
01blackgtconv
Aug 10, 2015 01:25 PM
