UDP's???
i've heard a lot of ppl say that UDP's wont cause charging issues but not of those ppl have sound systems. i have a in dash tv, 2 12' subs, a 1000 watt amp and a 600 watt amp. but i also have a optima yellow top battey do you guys think i'll have charging probs?
I get shouted at every time this topic **** up...
For the hp gains, i think they are a waste of money an youre only askin for problems when you use em.... just my humble opinion... *puts fire suit on*....
Bring the cap back if you can. It's a gimmick. It DOES work, but it's not needed at all. If you upgrade your big 3 wires (google Big 3 wires/audio, whatever), it has the same effect. Costs peanuts to upgrade, all you're doing is replacing the factory wires with a thicker guage.
http://www.cadillacforums.com/forums...m/t-82961.html
Well a cap might still be good for you. You've got alot more power than I used to run. I had a 1200 amp hooked up to a 15", and small 50w x 2 for the components, and I had my rear speakers taken out. My lights dimmed only a little, but it drained out my battery once. Had to call AAA. People told me to get a cap, and I did the 3, never had the problem. I was thinking of getting a HO alt. Luckily I didn't cause now I've got the Stang.
