Running lean
Old Sep 21, 2006 | 02:08 PM
ByPopularDemand's Avatar
ByPopularDemand
Default Running lean
Ok can running lean create a misfire...Or a misfire cause a car to run lean...I was shooting white clouds of smoke and getting like 2 miles to the gallon, I changed the plugs and no more smoke, and mileage is up. What else could cause leaning and misfiring
Old Sep 21, 2006 | 03:29 PM
cobra232's Avatar
cobra232
Default RE: Running lean
running lean will almost always cause a misfire especially at full throttle.
white smoke and white glazing on the plugs is indicitive of a lean condition or even a red burnt appearance to the plugs shows very lean.
fuel pump and fuel pressure reg can cause lean conditions as well as a bad maf and upstream o2 sensor
Old Sep 21, 2006 | 05:22 PM
Turkeyboy's Avatar
Turkeyboy
did you recently put on a cai? when i put mine on it wasnt tightend all the way and it seperated, and i got a system to lean engine code, Check and make sure your intake is properly fassend
Old Sep 24, 2006 | 05:06 PM
ByPopularDemand
ORIGINAL: cobra232
Could it also be from bad spark plugs or a cracked exhaust manifold
Jb145700
Aug 21, 2022 06:37 AM
Oct 7, 2015 07:02 PM
heslekrants
Sep 23, 2015 04:02 PM
TorinoCobra070
SVT Forums
Sep 18, 2015 10:34 AM
uedlose
Sep 10, 2015 03:30 PM
