Bigger rims affecting spedometer...
Old Jul 25, 2004 | 09:58 PM
red2k1gt's Avatar
red2k1gt
Default Bigger rims affecting spedometer...
Ive got a 96 coupe and recently upgraded from the stock 195/55/15 rims and tires to a new set of 245/45/17 rims and tires. About how much is this going to through the spedometer off?
Old Jul 26, 2004 | 12:21 AM
TattooTears's Avatar
TattooTears
Default RE: Bigger rims affecting spedometer...
I wasn't aware the getting bigger rims affects the speedo
Old Jul 26, 2004 | 12:32 AM
matthockey32's Avatar
matthockey32
I ♥ Acer
it will only affect your speedo if the tire height is different. in your case it is affected. at 60 mph on you speedo you will actually be travelling 65.7 mph. your stock tire size is 9.5% faster than your non-stock tire size.
Old Jul 26, 2004 | 12:52 AM
Jugador's Avatar
Jugador
but you're making the odometer think you're putting less miles on it
Old Jul 26, 2004 | 01:21 AM
matthockey32
I ♥ Acer
yeah but since that is illegal, you could have a chip done up to fix the problem. hopefully, without affecting your odometer. no one has to know.
Old Jul 26, 2004 | 10:10 PM
red2k1gt's Avatar
red2k1gt
I have a diablosport already in is this fixing my little speedo prob?
Old Jul 27, 2004 | 01:34 AM
matthockey32
I ♥ Acer
not unless it is programmed to fix it, which i doubt it is. go to where you had it installed and have them reprogram it to fix the speedo.
Old Jul 27, 2004 | 01:48 PM
callmecobra's Avatar
callmecobra
if your speedo changed, it went back to where it was supposed to be. 245/45/17 is how 17" tires are stock from ford.
Gene K
Oct 21, 2015 11:37 PM
UrS4
Sep 30, 2015 10:13 AM
LiquidDrink
Sep 29, 2015 10:06 AM
vintageaion
Sep 8, 2015 10:45 AM
