quick easy brake question
Old Nov 7, 2006 | 09:53 PM
ionlygot6's Avatar
ionlygot6
Default quick easy brake question
anyone know a good way to compress the piston when youre doing brakes. i know mustangs have to spin as you compress them. theres some tool out there but does anyone else know a different way, or where to get the tool? thanks
Old Nov 8, 2006 | 02:28 AM
ionlygot6's Avatar
ionlygot6
Default RE: quick easy brake question
bump
Old Nov 8, 2006 | 04:37 AM
SXGT's Avatar
SXGT
are you trying to change your brake pads?
Old Nov 8, 2006 | 09:21 PM
johnt2k7's Avatar
johnt2k7
put 1 of the old brake pads on the piston then use a c clamp to compress th piston but make shore that you do the 1 side and put it all together before u do the other side or it will just shoot the other back out
Old Nov 8, 2006 | 09:38 PM
98ponycar's Avatar
98ponycar
The tool you're referring to is used for the rear. It can be purchased through any major tool distributor. You can probably even rent one from Autozone. I don't recommend using anything other than the specific tool. You don't want to damage the piston. The front pistons will just push right in, and the rear turn and compress.
Old Nov 8, 2006 | 09:53 PM
dapack69's Avatar
dapack69
Yes you can rent the tool from AutoZone, I work there part time.
Remember to also remove the master cylinder cap when you push the piston in.
Old Nov 9, 2006 | 01:31 AM
ionlygot6's Avatar
ionlygot6
tommorow im installing rotors and pads in front. ive never done front brakes on my car, only rear. so thats good to know about the font. any suggestions on things not to forget haha?
Tivo304
Aug 28, 2023 12:19 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
cbird1177711
Sep 2, 2015 08:51 PM
