Appropriate pak
I'm having a 4.2L Stroker kit, http://rpm-mustangs.com/cart/product...cat=280&page=1, installed into my 3.8L block. On top of all this i'm looking to install a SSM Stage 3 powerpak, http://www.supersixmotorsports.com/p...2PowerPaks.pdf, before my turbo, http://www.tmaturbo.com/streetkit.htm , install.
My question comes from the fact that SSM offers a 4.2L Powerpak for 99-up mustang and V6 F-150 but the only stage 3 pak for 94-98 mustang is for the 3.8L. Could i still use this pak or would i be SOL on getting the pak at all?
Oh, while you're at it, do the intake swap. A 99-04 intake will bolt right up to the 94-98s, you just need the swap kit. http://www.rpm-mustangs.com/ sells both the intake swap kit with the intake, heads, gaskets, wiring harnesses, throttle body, bolts, and vacume lines, or you can buy the kit without the heads and intake and get the stage 2+ kit for a 99+ and do the swap that way.
No, but you may, key word there, may experiance some weird problems with idel as that system is made for high flow intakes. Like I said, may, it's not guranteed because there is so much crap that goes on with airflow inside the intake. You should be fine, but remember, the 2+ is going to be perfect for you, even if you go F/I, you're not missing out on much over the stage 3.
One more question. SSM offers the buyer a choice of camshafts, does anyone have any idea which cam i should look to get, this is what i was looking at:
Compcams'
Duration Lift Rockers LSA
216/216 .48/.48 1.73 1 14
Compcams'
v6turbo
Sep 21, 2008 03:06 PM
