Vacuum hoses!?!?
Old Nov 22, 2006 | 08:22 PM
  #21
Chadzilla's Avatar
Chadzilla
Default RE: Vacuum hoses!?!?
Well, I popped the hood and started the car. I reved it manually using the throttle body by hand. Upon full throttle, the cable would snap the throttle back shut, just like its supposed to. So, there is no problem with the throttle sticking. The engine sounds fine, but when you crawl under the car, there is a noise coming from around the transmission, sort of a metal on metal noise. Its not the belts, so im assuming its the clutch. There is no sign of slippage, but this noise is coming from the clutch, and only slightly changes when the clutch is engaged or disengaged. Maybe I will try to take a video so you guys can further understand. This worries me alot. THe car only has 45k miles on it.
Old Nov 23, 2006 | 04:54 PM
  #22
Chadzilla's Avatar
Chadzilla
ttt
Old Nov 23, 2006 | 05:03 PM
  #23
Durr727's Avatar
Durr727
ORIGINAL: Chadzilla
ttt
ok can somebody tell me wat the **** ttt means. i see it used and i have no idea what it means.
Old Nov 23, 2006 | 05:06 PM
  #24
africkanV6's Avatar
africkanV6
same...i think its the same thing as bump.
Old Nov 23, 2006 | 05:09 PM
  #25
Durr727's Avatar
Durr727
ORIGINAL: africkanV6
I guess typing bump it too much of a pain, 1 more letter, ooo. lol
Old Nov 23, 2006 | 05:11 PM
  #26
africkanV6's Avatar
africkanV6
ORIGINAL: Durr727
lol
Old Nov 26, 2006 | 10:42 PM
  #27
Chadzilla's Avatar
Chadzilla
I pulled the IAC valve today, and cleaned it with carb cleaner. Put it back on, and nothing changed. I noticed a screw with a spring on it inside the IAC. Could adjusting this make any difference? Im so frustrated.
mrtrodonet
Sep 19, 2020 03:12 PM
baddog671
Jul 26, 2016 01:20 PM
lmurf60
Sep 24, 2015 10:07 PM
LivingInThePast
Sep 16, 2015 12:20 PM
TfcCDR
Sep 14, 2015 12:08 PM
