Speedometer jumps
Old Aug 28, 2004 | 05:04 PM
sarahsmustang's Avatar
sarahsmustang
Default Speedometer jumps
Working on my daughters 95 Mustang convertible, V6 automatic.
The speedometer jumps around, sometimes it doesn't work at all, then will jump up and work fine for a few minutes, then drops to zero.
I changed the speed sensor at the tranny, the gear on it looked fine, no chipped or broken teeth.
Your thoughts?
tas
Old Aug 29, 2004 | 06:34 PM
e40water's Avatar
e40water
Default RE: Speedometer jumps
Just a guess maybe the speedo gauge maybe worn out or loose, May have to take off the clear plastic cluster see if the speed pin is loose.
Good Luck
Nurdyguy
Jan 20, 2025 04:38 PM
jwog666
Dec 27, 2021 08:09 PM
articman
Jun 21, 2018 11:45 PM
Beerman309
Sep 19, 2015 01:16 AM
