v6 vs v8 engine
Old Dec 5, 2006 | 06:32 PM
frost0526's Avatar
frost0526
Default v6 vs v8 engine
its it true that v6 are weaker engines then v8 a mean i heard v8 last longer and have less problem then v6 and that v6 break down more do u guys think thios is true
Old Dec 5, 2006 | 06:34 PM
GregoryA44's Avatar
GregoryA44
Default RE: v6 vs v8 engine
no 3.8 last longer!
Old Dec 5, 2006 | 06:49 PM
IFlanagan's Avatar
IFlanagan
Get a 3.8, far easier to work on, last longer, etc
Old Dec 5, 2006 | 06:55 PM
mustangman02232's Avatar
mustangman02232
the 3.8 block, and crank are some of if not the strongest in the whole ford line, talk to cobra232 about this but i believe the 3.8 has stronger rods and mains then a 302 and has better flowing heads then the 5.0 or NPI
Old Dec 5, 2006 | 07:17 PM
SilvrStang's Avatar
SilvrStang
yeah 3.8 have hell of a block. It can take i think about 450 to the wheelz stock! . Thats pretty awesome!
Old Dec 5, 2006 | 07:21 PM
BillyBobJoe's Avatar
BillyBobJoe
altough the V8 has 2 extra cylinders, and starts with more power. I tell my self that our little pushrod 3.8s have more potential. Just takes a lot of money. I think with the overheard cam design, theres more parts to blow up so thats why we can trust ours a lil more.
Old Dec 5, 2006 | 07:22 PM
Jugador's Avatar
Jugador
ORIGINAL: mustangman02232
stock doesn't mean much when aftermarket parts are super cheap (IE 5.0's). 5.0's aren't known for their strong blocks, but 3.8's aren't known for being relatively easy and cheap to get to 500 hp (point where a 5.0 block is going to be pretty stressed), so that point doesn't have much value.
Old Dec 5, 2006 | 07:23 PM
SilvrStang's Avatar
SilvrStang
money is everything. I think with about 5-6 grand of mods you can make your car a beast but its still 5-6 grand!
Old Dec 5, 2006 | 07:24 PM
mustangman02232
ORIGINAL: SilvrStang
matt neuthart has 750
Old Dec 5, 2006 | 08:14 PM
cobra232's Avatar
cobra232
he was saying on an internally stock 3.8.
as for frost0526, the ford 3.8 was copied off of the buick 3.8 but ford identified the buicks downfalls and weaknesses and improved on the buick design. the 3.8 is a very strong and reliable design. the earlier 3.8's (pre 96 1/2) had head gasket issues because of too many and too large water jackets in the block and heads. this can be fixed using the 99+ ford MLS headgaskets. it safe to say that 97+ engines are extremely durable even when a turbo or blower is used assuming the proper fuel upgrades and tuning is done
here is a link for you to read over even if you don't understand alot of it it's good reading
http://www.babcox.com/editorial/ar/ar90134.htm
