tires
Old Dec 20, 2006 | 10:56 AM
flash20's Avatar
flash20
Default RE: tires
i have kuhmo's 245 in the fron and kunho's 275 in the back
Old Dec 20, 2006 | 11:15 AM
Jefferson's Avatar
Jefferson
Moderator
Default RE: tires
I would think that 275s on the front of a near stock sixer would look nice but you would notice some slow down.
Old Dec 20, 2006 | 06:00 PM
jj84756's Avatar
jj84756
Default RE: tires
i really have liked my kumho's. i will buy more of their tires.
Old Dec 20, 2006 | 06:06 PM
flash20's Avatar
flash20
Default RE: tires
ORIGINAL: jj84756
+1 good tires
Old Dec 20, 2006 | 09:05 PM
cobra232's Avatar
cobra232
Default RE: tires
ORIGINAL: nanaki
ORIGINAL: baddog671
275's all round is a bad idea...
he's right. i have 275 all around on my car. 2 Nittos on the rear and 2 Kumhos on the front. the car pulls and is very touchy and sensitive when you turn the wheel. stay with 245 on the front.
only reason i did it was to be a cheapass. i wanted new rear tires but needed front ones. so i bought DRs for the rear and put my old rear street tires on the front. big mistake.
mustangs are not setup to run 245 up front and 275's out back. the suspension and chassis is designed for all four tires the same size. the BMW Z4 Chrysler crossfire and many other european cars are setup to run wider in the rear and narrower up front and they handle great like that.
the reason your steeringis touchy is because the 275's all the way around are very responsive. yes they do tend to track abit on highway grooves made by trafic but nothing that is untolerable.
using 245's in the front and 275's in the back eliminates and chances of proper rotation and handles worse that just running 245's on all fours or 275's on all fours. my cars tended to plow (understeer) on the track using 245's in the front and 275's in the back.
275's all the way around made the car extremely easy to throw around the track because of the predictability of zero understeer and very little oversteer.
if your car tracks or wanders too much with 275's you either need alittle wider rim and or adjust the camber/castor or switch to urethane bushings
another reason you have that problem is using 2 different brands of tires. Kuhmo's are alot harder compound than the nittos and the tread design is different. it would be like running V6 struts in the front and MACHI struts in the rear
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
KingRando
Oct 2, 2015 08:06 AM
marc954
Sep 29, 2015 11:18 AM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
