LT header problems
Old Dec 29, 2006 | 10:36 PM
ByPopularDemand's Avatar
ByPopularDemand
Default LT header problems
Ok so they are on as well as the or H pipe but I have no mufflers right now. The problem is the car decided to start runnin like ****.It starts sputtering and the RPMs drop like its about to die then it magically roars to life and is fine. It feels kinda like theres somethin wrong with the air, like the engine is having breathing issues. Could this be from the severe lack of back pressure or should I look for something else...
Old Dec 29, 2006 | 10:54 PM
johnt2k7's Avatar
johnt2k7
Default RE: LT header problems
do u have cats
do u have a mil iliminator
if u have neither the computer has gone into limp mode
Old Dec 29, 2006 | 11:01 PM
mvr's Avatar
mvr
sounds like you need a tune!
Old Dec 29, 2006 | 11:09 PM
NvRdoNeStAnGsIx's Avatar
NvRdoNeStAnGsIx
I dont think catless exhaust will set the computer off. However, it is your computer shutting your engine down.
You need MiL Eliminators to run an H-Pipe i believe. Pick some up on overnight shipping and hook up a catback exhaust system to it. Go with Magnaflow.
Old Dec 29, 2006 | 11:39 PM
mvr's Avatar
mvr
"Malfunction Indicator Light Eliminators, are electronic devices that prevent your "Check Engine" or "Service Engine Soon" light from coming on when an offroad H or X pipe is installed on a late-model vehicle with OBD-II emissions systems. If you install an Offroad H or X pipe on your car without MIL Eliminators, your "Check Engine" or Service Engine Soon" will always be on, and you won't have the opportunity of being alerted if something more serious is wrong with your vehicle."
i would suggest getting your car dyno tune, it will most likely get rid of this problem and you might free up some ponys
Old Dec 29, 2006 | 11:52 PM
johnt2k7's Avatar
johnt2k7
if u run a car with out the eliminators it will set off the light and go into limp mode which will make the engine run funny and stall and burn gass like crazy
all u have to do is get mil eliminators and get some one to clear the code on the computer with a scan tool or a programmer
or u could just get a programmer and turn the 02 sensor off and clear the code
Old Dec 29, 2006 | 11:54 PM
ByPopularDemand
I put the mil eliminators on the same day
Old Dec 29, 2006 | 11:58 PM
johnt2k7's Avatar
johnt2k7
do u have a light and did u start it with the new midpipe before u installed the eliminators
Old Dec 30, 2006 | 12:11 AM
deezelnut's Avatar
deezelnut
I ♥ Acer
sounds like the idle air controller is not working right.
Old Dec 30, 2006 | 12:15 AM
ByPopularDemand
Yes a light popped on today and I dont think I did
