LT header problems
Old Jan 4, 2007 | 12:10 AM
  #21
amrcnidyot's Avatar
amrcnidyot
Default RE: LT header problems
ORIGINAL: ByPopularDemand
ORIGINAL: Jugador
if you didn't accidentally unplug the wires or take if off completely, i doubt it's the culprit
Yeah I fried my front o2 sensors
how did you do that?
Old Jan 4, 2007 | 12:15 AM
  #22
Durr727's Avatar
Durr727
^ yeah, did the LT's do that?
Old Jan 4, 2007 | 12:19 AM
  #23
ByPopularDemand's Avatar
ByPopularDemand
I have 85k on the clock and new o2 sensors are part of a 90k mile tune up
Old Jan 4, 2007 | 12:28 AM
  #24
cobra232's Avatar
cobra232
even if you are catless you won't go into limp mode unless the front O2's are not working. the downstream o2 sensors are for cat function only. if the cats are removed the rear o2's sense that and throw the check engine light but it will not go into limp mode as long as the front sensors are good.
the front sensors are for air fuel metering and have nothong to do with the cats of what type of manifold you have. if you throw 24lb injectors on the car without a tune the front o2 sensors will sense too much unbuirnt fuel and throw a code and go into limp closed circuit mode. as long as everything is the same and just the headers were changed your car should not go into limp mode assuming the front sensors are fine
Old Jan 4, 2007 | 01:53 AM
  #25
ByPopularDemand
I dont believe the car is in limp mode...it certainly doesnt feel limp...the code just bothers me and I dont think I will pass emissions with it on
Old Jan 4, 2007 | 01:56 AM
  #26
amrcnidyot's Avatar
amrcnidyot
so is it still running like sh*t?
Old Jan 4, 2007 | 01:09 PM
  #27
ByPopularDemand
No its running good, but I have to change the driverside o2 sensor today
Old Jan 4, 2007 | 03:03 PM
  #28
amrcnidyot's Avatar
amrcnidyot
glad to hear its running good. that shouldnt betoo hard to do. good luck.
Old Jan 5, 2007 | 02:20 AM
  #29
ByPopularDemand
Aah no more light and running strong...its pretty nice
Jb145700
Aug 21, 2022 06:37 AM
SSG Steggy
3.7L V6 Technical Discussions
Nov 5, 2015 03:09 PM
Luke9222
Oct 22, 2015 11:55 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
Luke9222
Sep 4, 2015 06:46 AM
