overdrive
Old Jan 2, 2007 | 10:35 AM
Slow 99 mustang's Avatar
Slow 99 mustang
Default overdrive
I know this is prolly a dumb question but wat exactly is the overdrive for and when and how am i supposed to use it. i have a automatic 99. Also the other drive gears when are they supposed to be used.
Old Jan 2, 2007 | 12:17 PM
jthorn9's Avatar
jthorn9
The Godfather
Default RE: overdrive
Unless you see OD off on your gauges (a green light) then it's on. There is a gray button on the side of the shifter that turns it on and off. Overdrive saves gas by changing up the shifting points/ratios during normal driving. In other words, it makes you shift through the gears quicker keeping your rpms down and saving gas. Another way to look at it is, at 55 mph you might be in a high 3rd gear running with OD off, with it on, the car will shift to 4th droping the RPMS down to 1800.
Old Jan 2, 2007 | 01:40 PM
mustangman02232's Avatar
mustangman02232
overdrive locks the car out of 4th gear, thats it, if you go more then 50 mph i turn it on, less i shut it off, it saves gas, having it off around town keeps it from boging,
Old Jan 3, 2007 | 09:07 PM
Slow 99 mustang
ok thanks guys
Old Jan 3, 2007 | 10:31 PM
ByPopularDemand's Avatar
ByPopularDemand
I leave it on all the time unless im racing and need an rpm boost into the powerbamd
Old Jan 3, 2007 | 10:42 PM
mustangman02232
turning it off does nothing but lock it out of 4th gear
Old Jan 3, 2007 | 10:53 PM
ByPopularDemand
Yeah but fourth gear is weaker than third
Old Jan 3, 2007 | 11:09 PM
mustangman02232
cause 4th is .70 and 3rd is 1:1
Old Jan 3, 2007 | 11:18 PM
ByPopularDemand
Right...which is why it makes sense to race in the stronger gear if both can get to the limiter
CarrieS
Sep 1, 2015 01:00 PM
erig94gt
Jun 11, 2005 03:14 AM
BlackGT5.0
Feb 15, 2005 01:05 AM
89stanglx
Feb 3, 2005 11:17 PM
88_5.0
Dec 24, 2004 04:17 AM
