overheating ?
Old Jan 25, 2007 | 04:45 PM
S1ckness's Avatar
S1ckness
Default overheating ?
I recently put a new thermostat in my 98 v6 3.8l stang, its 195 degrees, when I drive it for about 10 minutes the heat guage reads that its overheating, like it will go to the " H " as far as it can go. Is this something normal for this? Can I keep going with it that high or do I keep pulling over?
It's a weird problem, it started with the new thermostat...
Thanks for the replies in advance...
Old Jan 25, 2007 | 05:01 PM
raz54's Avatar
raz54
Default RE: overheating ?
No that's not normal. Maybe you got an air lock and the water isn't circulating.
Old Jan 26, 2007 | 02:40 AM
S1ckness's Avatar
S1ckness
I forgot to mention that if I let it drift or shut it off long enough to run a normal temp, I will get heat, and it will stop over heating... It only does it untill I get heat...
Old Jan 26, 2007 | 04:47 AM
Autobadges.com's Avatar
Autobadges.com
Banned
Change it to a 190 degree thermostat
Check waterpump, radiator, change hoses and make sure fan works
if all of those are good u won't have any overheating problems but when the new thermostat was installed was the system BURPED to get all the air bubbles out? if it wasn't thats a huge problem bc in air bubbles take room up where coolant should be and your system will think more coolant went in then it really did and it throws the thermostat out of whack
Old Jan 26, 2007 | 04:56 AM
S1ckness's Avatar
S1ckness
No I did not " burp " it, how would I go about doing that?
Old Jan 26, 2007 | 05:01 AM
Autobadges.com
Banned
ok take the cap off the radiator and turn the car on. Easiest way to show you where the cap you need to take off is to follow these instructions
go to the front of your engine bay....left hand side is the hose that connects to your radiator..follow that...then it connects to the thermostat housing (steel pipe) and then it goes into your lower intake where the thermostat is.....on TOP of there you should have a yellow/off white cover with a big nut in the center with red writing on the cover. THAT is what you need to take off to 'burp' it...run the car with that open....when you see the coolant coming UP through that little tube the air is all gone...that is the 'escape' for air bubbles when the coolant is running. So you need to run the car until it heats up that the thermostat opens to cool it down for the air bubbles to leave
BOB ROME
Jul 26, 2023 01:54 PM
mungodrums
Sep 29, 2015 09:18 PM
yourmom6990
Sep 14, 2015 10:52 PM
MusicCity615
Sep 12, 2015 07:05 AM
96stang3.8
Sep 10, 2015 06:42 AM
