lights
Old Feb 28, 2007 | 11:16 PM
crmstang's Avatar
crmstang
Default lights
how hard is it to connect the wiring harness to the switch for some fog lights? it looks hard because you have to take all the center stuff out in order to get the wires up there.
Old Feb 28, 2007 | 11:21 PM
hpwrestler220's Avatar
hpwrestler220
Default RE: lights
no..the whole center piece around the controls pop out so you can get to them easily...i cant remember if you have to unscrew some things but its really easy man..it takes 2 seconds...i cant give a good explanation but they pop right out..the plastic pieces around ur center console around the shfiter and around the air vents and radio..than you'll have access to everything
Old Feb 28, 2007 | 11:31 PM
v6stang07's Avatar
v6stang07
Default RE: lights
its not very hard at all, just remove the shifter bezel and the center console bucket and u can reach everything u need
Old Feb 28, 2007 | 11:43 PM
v6stang07's Avatar
v6stang07
Default RE: lights
if u need a better visual, check the how to sticky and look at jovez's shift boot how to and u can see how to remove the shifter bezel and i have written a fog light how to on there, even if u dont have a 99-00 it is still the same install exept for the switch location
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Explosive
Oct 2, 2015 07:45 AM
folivier
Oct 2, 2015 05:34 AM
