1998 Mustang A/C Problem! Help!
Old Mar 12, 2007 | 04:48 PM
bluefish2007's Avatar
bluefish2007
Default 1998 Mustang A/C Problem! Help!
OK... here goes (I apologize for the length of this post)
1. Last fall I washed the engine on my 1998 3.8L v6 Mustang using the usual engine cleaning foam.
When finished I noticed air no longer blew from the ac/heater vents but only from the defrost vents. I poked around and discovered a vacuum hose was disconnected. I reconnected and worked fine for a month or so.
2. Next thing to happen was the ac/heat thermostat **** became slightly difficult to turn to the ac side. Turns easily to the heat side. It feels like some type of spring or cable attached to the **** is damaged, worn, or out of adjustment. I haven't torn the dash open to find out.
3. A few months later I could no longer get cold air from the ac. Air blows from the vents but never gets cold. Heater works fine. Took to a mechanic to check refrigerant level. He said refrigerant was fine.
He jumpered the ac compressor directly forcing it to come on. He said the problem was the ac compressor was not getting power. He wanted to charge me to replace entire HVAC system ($900.00+). I told him I'd think about it (meaning "are you crazy?!")
4. I did some research and heard about the ac clutch switch (on condensor) sometimes failing and therefore not allowing ac compressor to kick in. Took a paper clip and jumpered the ac clutch switch contacts (on the plug going to the switch on the condensor) and sure enough the ac compressor seemed to come on (did this with car running). Went out and bought a new switch and installed.
5. Now here is what happens... when I turn on the AC (normal or max) the compressor seems to kick in only for about 2 seconds then turns off. I hear the engine RPM's slow down (and see it on the RPM dash gauge) then the RPM's go back to what they were before turning on AC. A few seconds later the RPM's go down then back up. I turn off the AC and the RPM's stay steady. As far as I can tell the ac compressor is not on long enough for the air to get cool (assuming the air would get cool).
Despite the fact my refrigerent level is ok (or so I was told) could I still have a pressure problem?
Any ideas?
Old Mar 12, 2007 | 05:13 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Default RE: 1998 Mustang A/C Problem! Help!
Low side pressure switch on your a/c line. It's probably not sending the proper signal for the clutch to properly engage.
Ryan
djbigskrilla
Sep 20, 2022 01:04 AM
SANDY21
Aug 17, 2015 02:41 PM
gagemcc
Aug 17, 2015 10:30 AM
daytooday
Aug 11, 2015 09:22 AM
HIS S-197
Aug 10, 2015 05:47 PM
