PCV
Old Mar 22, 2007 | 07:16 PM
Baron von Munchausen's Avatar
Default RE: PCV
ORIGINAL: mcccop_04
would it matter if i put the valve on the passenger side? the fram valve i bought does not fit in the elbow on the drivers side but does fit the hose on the passenger side
The reason it's not on the passenger side is that some air is drawn into the crankcasevia the hose from the air intake, due to the negative crankcase pressure resulting from a properly functioning PCV valve. I wouldn't use breathers, because they are not as effective at eliminatingoil vapors and blowby gas, withresulting increased pressures, from the crankcaseas is the vacuum scavenging supplied from the intake manifold. The PCV system is more than just an emission control, it's a means of efficiently removing contaminants and pressure from the crankcase, good for the longevity of your engine and it's gaskets. The downside is that over time it does result in deposits on your intake manifold and piston tops, but that can be all but eliminated by using an in-line filter or catch can between the PCV valve and the intake mainfold orificeto which it connects.
Old Mar 23, 2007 | 12:47 AM
raz54's Avatar
raz54
Default RE: PCV
+1
Old Mar 23, 2007 | 09:33 AM
TheMichiganRA's Avatar
TheMichiganRA
Default RE: PCV
+2 that's what I've been told in my auto class.
Old Mar 23, 2007 | 12:37 PM
raz54's Avatar
raz54
Default RE: PCV
I wouldn't run without one myself. That little bit of vacume can help increase hp. A lot of racers would take old smog pumps and connect them up for even more vacume, now they sell crank case pumps just for that reason.
JonnyBlazeGT
Nov 3, 2015 01:10 AM
lmurf60
Sep 24, 2015 10:07 PM
Ipaman
Sep 22, 2015 07:01 AM
Scottyboy187
SVT Forums
Sep 13, 2015 10:23 PM
YoungStangsMan
Sep 5, 2015 07:01 PM
