PCV
Old Mar 21, 2007 | 11:20 PM
mcccop_04's Avatar
mcccop_04
Default PCV
I know most of you are gonna laugh and turn this thread into a whorefest but i got a question for ya, i was going to replace my pcv valve on the passenger side valve cover as my haynes book says. but when i pulled the line there was no pcv valve on there. moved to my driver side valve cover and the pcv valve was on that side. the question to you is does it matter which side the valve is on? thanks to everyone who stays on topic here
Old Mar 21, 2007 | 11:40 PM
RyansQuick6's Avatar
RyansQuick6
Reverse Gear Member
Default RE: PCV
It's on the drivers side. I did the same thing 2 days ago. I'm going to eventually remove both of those hoses and use breathers instead.
Ryan
Old Mar 22, 2007 | 12:05 AM
cisurfer's Avatar
cisurfer
Default RE: PCV
same im goin wit breathers and egr delete
Old Mar 22, 2007 | 12:24 AM
mcccop_04's Avatar
mcccop_04
Default RE: PCV
would it matter if i put the valve on the passenger side? the fram valve i bought does not fit in the elbow on the drivers side but does fit the hose on the passenger side
Old Mar 22, 2007 | 12:28 AM
RyansQuick6
Reverse Gear Member
Default RE: PCV
Yes it matters. I have a purolator in mine, it came with 3 adapters, since it needs an elbow for my car. Got it at Advanced Auto Parts.
Ryan
Old Mar 22, 2007 | 12:39 AM
cisurfer's Avatar
cisurfer
Default RE: PCV
i used a fram also...it comes with different adapters and it fits in the drivers side valve cover
Old Mar 22, 2007 | 01:32 AM
raz54's Avatar
raz54
Default RE: PCV
Why use breathers? They leak oil all down your valve covers. Why not just put in an oil separator instead? Your engine will stay clean and it will still pass smog.
Old Mar 22, 2007 | 01:53 AM
cisurfer's Avatar
cisurfer
Default RE: PCV
cuz im putting a eaton m112 on my car and i dont feel liek dealing with all that ****
Old Mar 22, 2007 | 02:25 AM
raz54's Avatar
raz54
Default RE: PCV
That's a good reason
Old Mar 22, 2007 | 06:18 PM
98Ga's Avatar
98Ga
Default RE: PCV
does this add more power?
