How do u remove the lower door hinge?
Old Apr 10, 2007 | 11:02 AM
lioneljones2001's Avatar
lioneljones2001
Default How do u remove the lower door hinge?
i got a 2004 mustang and i was wondering how to remove the lower door hinge, all i see is two bolts, i removed them, but the hinge still dosent come off.
Old Apr 10, 2007 | 11:40 AM
FBCBEER's Avatar
FBCBEER
Default RE: How do u remove the lower door hinge?
it could be welded a little on there too...I dont know though.
Old Apr 10, 2007 | 03:57 PM
Jugador's Avatar
Jugador
why are you removing it? they may tack it on in a few spots but i dont think it would be an easy fit to get a grinder in there, especially if you havent taken the door off. cant you just remove the door pins and bushings to get the door off or is that not what you want to do?
Old Apr 10, 2007 | 05:03 PM
lioneljones2001
im putting on lambo door hinges, i removed the door and fender, but the lower hinge on the car wont budge for some reason
Old Apr 10, 2007 | 07:06 PM
Jugador's Avatar
Jugador
have you tried anything to pry it off? see if you can fit something underneath all the edges of it to see if there are any welds. if there are, you're probably going to have to grind them off. i don't know how it's set up. it may just be stuck on by the paint holding it together.
Old Apr 10, 2007 | 07:23 PM
lioneljones2001
i tried that also, there are no welds, i think there is a hiden bolt behind the door stop mech, so im going to check it out again
Old Apr 12, 2007 | 08:27 PM
lioneljones2001
i figured it out, there's a reversed bolt behind the kick wall, 13mm
Old Apr 12, 2007 | 10:07 PM
crusher101's Avatar
crusher101
PICS!
fcarpio
Suspension
Nov 16, 2018 10:35 AM
ccdguy
Sep 19, 2015 05:20 PM
FivePointToTheOh
Sep 14, 2015 03:35 PM
wawagner82
Sep 13, 2015 09:02 AM
Doogie65
Sep 6, 2015 02:55 PM
