NEED HELP!!!! shed some light!
Old Apr 17, 2007 | 03:11 PM
02ponypackage's Avatar
02ponypackage
Default RE: NEED HELP!!!! shed some light!
it takes longer to jack the car up then it does to remove and install a new fuel filter....its easy as hell...and the Ford dealership wants 80$s to do it...haha crooks
Old Apr 19, 2007 | 01:53 PM
blknismo180's Avatar
blknismo180
thanks guys.....so abuot the tranny fluid what should i do....just take off the pan and replace or leave it alone.....?
Old Apr 19, 2007 | 02:00 PM
laserred02's Avatar
laserred02
so it seems that you are willing to do some routine maintenance on your car, and maybe a little more involved work. I'd say it is time to invest in a Haynes or Chilton repair manual for your car. they are less than $20 and while they aren't the best manual they will help you a lot. as for the tranny fluid, loosen the bolts on the pan let one side down first and drain the bitch, replace gasket and filter and then refill. I'm not sure where you fill on your car because i have a 5-speed, but if you get the haynes manual it should tell you. good luck!
Old Apr 23, 2007 | 01:41 PM
blknismo180
Default RE: NEED HELP!!!! shed some light! FILLER NECK GASKET
I CHANGED THE FILLER NECK GASKET.......ALL BY MYSELF DROPPED THE TANK.....IT SUCKED SO MUCH.........BUT I DID IT..... IT WAS SO HARD TO GET THAT NOZZLE THROUGH THE RUBBER GASKET......BUT WD40 HELPED......FOR SOME REASON KNOW THAT I REPLACED IT IT FEELS LIKE IT WAIST MORE GAS?????![>:].....OR I DID IT WRONG....BUT COULD IT BE BECAUSE I DIDNT REALLY KNOW WUT THAT PART WAS AND HAD ONLY YOU GUYS HELP ME AND I FEEL SELFCONCIOUS ABOUT IT? OR I REALLY DID SOMETHING BAD......THE OLD GAKET WAS RIPPED 3/4 OF THE WAY....AND HAD DRIED WAXY GAS ALL OVER THE TANK.......
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Explosive
Oct 2, 2015 07:45 AM
ChampInSD
Oct 2, 2015 04:55 AM
