any know these codes?
Old Apr 26, 2007 | 12:26 AM
blknismo180's Avatar
blknismo180
Default any know these codes?
okay i have a 2000 v6 stang....read the codes that came up....these are it..........P1309 and P0340...... any one know what these are...?
Old Apr 26, 2007 | 12:39 AM
laserred02's Avatar
laserred02
Default RE: any know these codes?
p0340 is a camshaft position sensor circuit malfunction -
p1309 misfire monitor disabled- when the misfire monitor is disabled, usually due to the input signal generated by the camshaft position sensor by sensing the passage of teeth from the cmp wheel. verify the camshaft position sensor is installed correctly and not out of synchronization.
this is what the code troubleshooter i have says, i've never dealt with these codes so i can't give advice beyond that
Old Apr 26, 2007 | 12:57 AM
SilverOnyx1's Avatar
SilverOnyx1
P1309 Misfire Monitor AICE Chip Fault
P0340 Camshaft Position Sensor Circuit Malfunction
The Camshaft Position Sensor probably has gone bad and needs to be replaced. If you DIY, the part may cost you $50 - $90 bucks. Not sure what a shop will charge with labor.Personally, Iwouldn't drive until I found out exactly what is wrong.
Old Apr 26, 2007 | 05:26 PM
blknismo180
i just replaced the camshaft synchronizer and it cam with the top...... i dont know what the sensor looks like but.... i know that i replaced it..... i cant find anyone to diagnosis this for cheap...i call every where and it is about 80 bucks avarage so far...but like i said i just replaced it....
Old Apr 26, 2007 | 05:30 PM
crusher101's Avatar
crusher101
maybe you installed improperly
Old Apr 26, 2007 | 06:30 PM
Jefferson's Avatar
Jefferson
Moderator
http://www.troublecodes.net/Ford/
Old Apr 26, 2007 | 06:37 PM
Derf00's Avatar
Derf00
Gentleman's Relish
ORIGINAL: crusher101
That is the most likely culprit. The Cam Sensor error leads to the misfire error. Fix the Cam Sensor and you get rid of the other code as well.
Blknismo180 - How can you replace something and NOT know what it looks like?
This a tool you need to properly align it.
http://www.etoolcart.com/index.asp?P...mp;ProdID=3878
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
ChampInSD
Oct 2, 2015 04:55 AM
