No Spark
Old May 11, 2007 | 11:33 PM
fgorton's Avatar
fgorton
Default No Spark
I just put a 97 3.8 engine in a 94 -it came complete with the wiring harness. Everything is put back together and when I turn the engine over I get no spark. Any ideas why?
Thanks
Old May 12, 2007 | 12:32 AM
Whitecomet25's Avatar
Whitecomet25
Default RE: No Spark
Do you hear the starter? ( the car turn over but not start) You can take a sparkplug wire off to see if it sparks when someone turns your car over, if not check the distributor, It could be your coil.
Old May 12, 2007 | 01:24 AM
fgorton's Avatar
fgorton
I replaced what would be the distributor ( the other end of the plug wires - can you tell I'm an amature mechanic?) on the 3.8. I have taken the plug out, turned the starter and there was no spark. As I mentioned I changed the engine from a 94 to a 97. Can the computer cause this? The battery was out for about two weeks while I swapped out the engine.
Old May 12, 2007 | 01:38 AM
Whitecomet25
ORIGINAL: fgorton
The engine is the same and there was no change untill the 99 mustang ( splitport rather than single port) Was the distributor form your engine or the 97 engine's . You can take the distributor to autozone and have it checked out.
Old May 12, 2007 | 11:34 AM
fgorton's Avatar
fgorton
I took the distributor from the 94 engine and put it on the 97. The 94 was running (barely) when I took it out so I would assume that it was good. I live in a rural area and an Auto Zone is more than 120 miles away.
Dathan
Oct 5, 2015 05:52 AM
dalehunter
Sep 25, 2015 10:51 AM
lmurf60
Sep 24, 2015 10:07 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Emblazoned
Sep 3, 2015 10:45 PM
