8.8 Differnetial...
Old Jun 3, 2007 | 05:26 AM
Zach3.8L's Avatar
Zach3.8L
Default RE: 8.8 Differnetial...
Mooses, my shop manual and the Master Tech at the shop I go to both say it's a 6.6
Besides, the ID tag on the diff itself says it's a 6.6 No joke. But still, will I have a better time with acceleration?
Old Jun 3, 2007 | 05:34 AM
lazypony's Avatar
lazypony
It might do something. Mostly, it's just stronger. And there are a few more options on gear ratios. But you do have the t-lok, which will help.
Old Jun 3, 2007 | 06:07 AM
mooses's Avatar
mooses
ORIGINAL: Zach3.8L
That's odd, I'm assuming you aren't the original owner? I don't see how it got on there, I don't even know if ford has a 6.6 rear.
In 98 the stock ratio for stick cars was 2.93. You had the the option to get a 3.27 but only with a stick. The auto always came with 2.73s
I found this on modulardepot, and it's the only thing I could find about an 8.8 out of a 98 GT. Basically if this is correct, then if the GT you got yours out of was a manual, then it will increase your acceleration. Of course, I can't say that for sure because I have no idea what gears you have currently in your rear.
Old Jun 3, 2007 | 06:43 AM
Zach3.8L's Avatar
Zach3.8L
It is out of a manual. As far as I know, it has the 3.73 gears inside it...
Old Jun 3, 2007 | 07:35 AM
Zach3.8L's Avatar
Zach3.8L
Here's a pic of the ride it's going on:
Keep in mind I changed the headlights (the whole assembly) a couple days ago and haven't gotten a pic of it yet.
[IMG]local://upfiles/61945/80888BBFD6C34947AED7B1F5E5CD87ED.jpg[/IMG]
[IMG]local://upfiles/61945/4C2AB98DC8D54148B4E5E971830CEC5F.jpg[/IMG]
Old Jun 3, 2007 | 01:54 PM
02MustangV6DD's Avatar
02MustangV6DD
yeah no 6.6 in Fords Mustangs. All 7.5 here, even if it wasnt factory, i dont belive ford made a 6.6. Make sure you change the fluid, and spray all the bolts down with WD40 or PB Blaster so it wont be such a pain in the ***.
Old Jun 3, 2007 | 01:55 PM
02MustangV6DD
http://www.richmondgear.com/01ford.html
Old Jun 3, 2007 | 02:13 PM
jthorn9's Avatar
jthorn9
The Godfather
ORIGINAL: Zach3.8L
The 94 to 98 model years had the 6.6
I did my homework on this one.
Sorry dude. 94-07 Mustang V6s use the7.5" rear end.Ford, to my knowlege, has never used any smaller inMustangs. 94+V8 stangs use the 8.8" rear end.
They guy that told you they use 6.6" was either confused, ora complete moron.
Old Jun 3, 2007 | 04:20 PM
Zach3.8L's Avatar
Zach3.8L
ORIGINAL: jthorn9
ORIGINAL: Zach3.8L
Like I said, the ID tag says it's a 6.6 no joke!
Old Jun 3, 2007 | 04:35 PM
jthorn9's Avatar
jthorn9
The Godfather
Dude, Ford does not make a 6.6" rear end, there is no way it's a 6.6". 94-98 V6 stangs come stock with an 7.5" rear end with 2.73 gears. 94-98 GTs come stock with an 8.8" rear end with 2.73 gears. SVO made a special edition 5.0 that was optional with 3.24 and 3.55 gear ratios.
