EGR
RE: EGR
ORIGINAL: 03sixbanger
oh well i guess that should stay then
RE: EGR
thanks guys, so no one can really get to it just removing the air intake. the only think i thought about was that crows foot but i dunno, i might end up doin sumthin else, i guess if i get a tuner i will jst cut it and not worry about it
RE: EGR
the first time i took it off i just used a wrench w/ a small pipe on the end. it takes some work but you can get it. ive also heard get some pb plaster and put it on there and let it sit for a while. should help. and like i was sayn v6stang, you dont have to take it off to move the valve.
RE: EGR
yea i see that
a general egr ? here
yesterday i put it all back on my car since i couldnt get the copper tubing off and i left the electrical connections off and my car seemed to run fine, that should be about the same as the delete shouldnt it??
RE: EGR
ORIGINAL: v6stang07
yea i see that
yea i see that
RE: EGR
yea it did finally throw the code
do u know if the electrical connection on the drivers side of the motor on top of the fuel rail goes to the egr???
it goes into the main wiring harness but it also connects with the egr harnesses???
