overheating
Old Sep 8, 2003 | 10:11 PM
fordgrl55's Avatar
fordgrl55
Default overheating
<FONT face="Times New Roman, Times, serif" color=black size=4>K..i have a couple questions...I went to look at a 93' today and the "only" thing wrong with it was that it overheated...what could be some causes of this??? the fan is running so its not like that is busted...thankx fer ur help...</FONT>
Old Sep 8, 2003 | 10:29 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Default overheating
When an engine overheats, the biggest concern is the heads, as they get the hottest. When you head heads up too much they can warp, causing the mating surface between the head and block to not be flush, blowing out headgaskets.</P>
Many things can cause cars to overheat, usually its a busted radiator hose or a thermostate stuck closed. Often times the culprit could be low coolant, blown headgasket (exhaust heating the coolant), cracked block, + other things I cant think of right now. Even if it runs fine today, you could still have 1 or more of the above problems. </P>
Determine if it just ran hot this once, then find and fix the problem. If it chronically runs hot, then you may have a more serious problem.</P>
Old Sep 9, 2003 | 02:06 AM
Kidrosey's Avatar
Kidrosey
Default overheating
</P>
And when head gaskets warp or the heads get cracked, coolantwill be sucked into the oil system. If there is a foamy slush in your oil system then you will know your problem - hope that's not it!!!</P>
Old Sep 9, 2003 | 02:08 AM
Kidrosey's Avatar
Kidrosey
Default overheating
BTW - mdvaldosta - do you sleep? ever? And are you in Valdosta, Ga?
BOB ROME
Jul 26, 2023 01:54 PM
mungodrums
Sep 29, 2015 09:18 PM
yourmom6990
Sep 14, 2015 10:52 PM
MusicCity615
Sep 12, 2015 07:05 AM
96stang3.8
Sep 10, 2015 06:42 AM
